Changing Power Steering Fluid
DUK-RNR
What I've found on line is, jack up the front wheels, suck the fluid out of the reservoir, then put fresh fluid in, start the engine turn the steering wheel back and forth, and repeat until the fluid is clear. This takes a long time.
Is there any reason why I can't pull one of the fittings loose from the rack , take the top of the reservoir and let it drain(engine off)
While we're at it doesn't power steering fluid work just as well as Dextron II?
You probably could do that but you will introduce a lot of air into the system, watch Timmy the toolmans video on YouTube he has 2 for flushing the power steering system. I kind of did a mixture of both of his videos, removed the fluid with a turkey baster and small syringe 5-10 times and then removed the reservoir and cleaned the screen.
Do not use power steering fluid. Different additives than transmission fluid.
X2 power steering fluid in our system will eat the seals and you will have a leaky rack very quickly, (ask me how I know). It says on the fill cap of the Power steering to use ATF and you will be very happy.
Suck old fluid from res.
Disconnect res return line.
Route res ret line into waste can.
No need to start engine.
With wheels off ground, work steering wheel back and forth. The old D-ATF gushes out into waste can.
Refill the res with new D-ATF periodically while doing this.
When you have exchanged a sufficient amount of D-ATF, re-attach return line to reservoir and top off res.
Start/run engine. Stop engine. Check level of D-ATF on dipstick and adjust. If it foams up(usually accompanied by a odd whine sound), let it settle for a while and add D-ATF to replace the settled-out air.
Detaching the reservoir in order to clean the screen at the bottom is optional, but will need to be done at some point.
Use only Dexron ATF.
Can I buy a reservoir for a 2.7 without a pump anywhere?
Had hard steering issues in the cold, did the reservoir pull and blasted the filter screen out with brake clean, couldn't get the factory crimps on the PS top tight enough. I got Ps fluid dripping down on belts and splattered into the bay. Belts a squeekin'
Part number for the reservoir is 44306-04020. What do you mean the factory crimps? Did you remove the top of the reservoir that the cap threads on to?
yes,Followed that aussie advice on the tubes, pried the 6 crimped connectors to get the top off, but you cant get them crush tabs back in right, Im getting leaks around 3 of the 6 coming out the top. It was a good work around but i don't advise, Also ripped the o ring going back in like everybody else. This is not a advised repair, buy a new rez or pump unit.
I wouldn't of removed the tabs. Cleaning the screen is best, but when I did it I just disconnected the return line to direct into a waste bucket and had the inlet tube in a large jug of Dex III for the flush.
Dex III is what you should use, some dealerships will use PS fluid. But there is no reason to use power steering fluid when you have access to the correct fluid. Use Dex III.
Having airbubbles in the fluid directly after a flush is unavoidable, just expect some whining after the first 10 minutes or so.
didnt remove, pryed them flat, rebendt them back
That’s the first time I’ve heard of anyone doing that. Everyone else just puts cleaner in the reservoir and shakes vigorously to clean the screen. Definitely wouldn’t recommend prying the tabs off for anyone else that comes across this.
thats sounds pretty half ass, hope they dont charge for that kind of work
It’s worked great for I’m willing to bet hundreds of people with great results. I’ve done it twice and you could visually tell the difference by shining a light through before and after. The best part is it doesn’t leak as long as you replace the o ring. You call it “half ass” but I call it “leakproof”.
Welcome to the forum by the way. Be sure to visit our sister forum pirate4x4 and tell them about your phenomenal method that is revolutionizing the way you leak fluid.
EDIT: Hope people don’t pay for what? A clean power steering reservoir that doesn’t leak?
problem is the rez cap gasket is 20 years old, its hard to recurl the stakes/flanges backdown enough to seal that gasket, some rtv might have helped. also in the video, my 2.7 rez didnt have a diffuser, more like a sterno can with fine screen in the bottom. The stake dimples were to deep to try to pull it out any angle, I just cleaned in place.
I've been here for over 8 years and Im never surprised by the attitudes of the power tripping mods here. Great way to destroy such a great community and forum.
Best way to interact with this site now is not to sign up and post and just do a google site: search, and let toyota-4runner.org bleed out adsense. Mods here are such ****ing *******s.
"Welcome to the forum by the way. Be sure to visit our sister forum pirate4x4 and tell them about your phenomenal method that is revolutionizing the way you leak fluid."
Spoken like a ***** raised by a *****. Enjoy your vagina
