Changing trim colors on my '03
What was the process in removing/replacing the roof rack, did you have to drop the roof liner inside the truck?!
No, you can unclip the end caps from the rack and there are two bolts under each cap. There's a writeup somewhere on the forum if you search. I believe you lift from the side that faces the center of truck and the end furthest from the center slides out in the plane of the roof.
Got my new (or at least new to me) rims on today. Also wanted to point out the new step tubes, thanks to Roll Tide, i painted and installed in place of my running boards. With all the changes this year it feels like a brand new truck.
photo-2.jpg~original
photo2-2.jpg~original
photo3-1.jpg~original
Same here. The wet sanding is the key. But you have to be careful not to go all the way through the clear coat
Yea, the key is to sand lightly until the sand paper is quiet. Once the scuffing sound goes away, you're piece is smooth as a baby's bottom!
I've painted a few guitars with rattle cans and time really is your friends!
Jhunt
