Chaotic Shifting
Diverse4runner
Im at a loss.
Problem = After probably like 30 to 45 minutes of driving my truck will go into a crazy shift pattern. 1, 2, OD, 3, OD, Torque lockup.
Things Ive tried and when it started. New TPS, adjusted TPS. I can play with the gas pedal to make it get out of OD after second gear. This all started after replacing the HG when they blew. Ive had three transmissions in this truck so I know its not that.
Im just looking for ideas.
Thanks Guys
Did they replace the solenoids when they rebuilt the tranny? Or did they just replace the clutches and clean out the valve body...
Are there any codes on the dash? A/T light? brake light? O/D light? Those are what came up when my solenoids went bad. Have you tried to shift manually?
Two of the transmissions are the latest ones. Both are not original and yes everything was replaced.
No codes on the dash I will try and shift manually next time it does it.
seltzernator
