Charging system help..
AlPalusky
Hi.. I am new here. I just bought a 91 4Runner. It has 117k. I replaced the battery, and the starter. Today I was working on the inside. Removing the back seat, and building a solid floor. The primary use of this truck will be towing our camping trailor. We also have a 06 Toyota Matrix. We can't use that for towing, because there is no frame under it. I have a problem though I think.. I had the front doors open for about 2hrs this morning. The lights in the doors work. After I was done with the floor I went to start it, and nothing.. No click.. Nothing. I put the charger on it, and it fired right up.. Are 4Runners that hard on batteries?? Is there a lot of draw on the starter??
My next question has to do with the anti-lock rear brakes. I have on both the brake light, and that anti- lock light. I am going to have the fronts and rears done on Tuesday. Is there a way to bypass that anti-lock?? Thanks.. Al
I know that nobody answered my question.. Well that doesn't matter any more. I was driving the other morning. I was only doing abot 15, or 20 mph. The frame snaped on first the passengers side. I noticed a little sag on that side, but I was on a rough gravel road, so I didn't think very much of it. Well then it snaped on the drivers side, and it dropped.. Bent and broke the driveshaft and all.. Ended up I got $100 for it from the scrap dealer.. Couldn't even save the engine. When it bottomed out it tore a hole in the pan. It all ended up junk. Well it was kind of fun while I had it.. Al
