I am having problems getting my 03 v8 to start. At first it was intermittant, for a day, then today it will not start at all.
Battery is charged and has good connections. The solenoid clicks with I turn the key, but starter is not doing anything. I think it is probably dirty contacts, or possibly a neutral safety switch.
The car will not start in any gear though, including neutral.
I need to check the starter's ground, that is my first suspect. I do not have a manual. Can anyone tell me where the starter grounds to?
The starter is under the intake manifold. Is there a way to check the connections on the starter without removing the whole intake?
Also, where is the starter solenoid, is it attached to the starter? I am by myself so I cant trace the sound and turn the key at the same time.
Thank you in advance!
