"Check Engine" light keeps coming on with aftermarket upstream O2 sensor.
Benski
Member
I had my check engine light (CEL) come on last week. I quick diagnosis showed it was the upstream O2 sensor. I replaced it with an aftermarket "direct fit" replacement. I reset the CEL and after several times turning the engine on and off and driving, the CEL came back on. A diagnosis showed it was the O2 sensor again. Has anyone has this same issue? Will it eventually stay off if I keep resetting it? What aftermarket sensor has worked for you? Thanks.
So before I get a chance to order a Denso O2 sensor or clean my MAF I go to run an errand, and on the way back I look at the dash and see the CEL is off! I've never had a CEL go off without a reset. I'll update if there is any change.
Is the wire badly damaged by chance?
Try replacing with a Denso.
I have also always heard to replace both if one goes.
Hello all, I’m working on my son in laws new to him, 2000 4 runner 3.4 2 wheel drive.
The check engine light is on so I will be replacing both O2 sensors and doing a timing belt replacement while I’m at it.
Where do recommend buying the sensors from? I only want denso (OEM I believe).
Thank you and sorry if I jacked the thread.
Amazon for Denso/OEM sensors or if you have an AdvanceAuto/carquest as they always have coupons 20-30% off
Thank you! I have not worked on a 4 runner before.
I’m finding denso’s with part numbers 234-4162 and 234-4169, sound like the right ones?
* editt* The 4162 looks right, not the 4169. I thought there were 2 of em
If its 50 state/CA emissions then 234-4153 (downstream) and CA 234-9002/9003 upstream- CA vehicles have a Air/Fuel sensor.
234-4161-non CA 2wd
234-4154/4155non CA 2wd
You can pull it as it's 2 14mm nuts and check the numbers etched around the body
234-4161-non CA 2wd
Thanks for the info! those 2WD numbers on amazon say they will not fit my vehicle. I’m going to start a new thread so I don’t mess with the OP.
Put it up on the lift last night and the O2 sensors look new (one in front of the cat and 1 behind), hard to tell what brand. Went to auto zone this morn and pulled a P0171 code.
234-4161-non CA 2wd
Not true. The numbers on the body have no relation to the p/n. The same body is used for many p/n's as they vary mainly by wire length.
Also, the nuts are stainless M8-1.25 and they take a 12mm wrench if they are OEM nuts.
To be sure of part number, you need year, transmission, engine, 2wd/4wd and Cali or Federal in '99 or '00.
Go here:
http://densoautoparts.com/find-my-part.aspx
P0171 and sulfur smell is more likely a MAF issue anyway. Start by cleaning it.
Thanks for the link!
So my understanding is the A/F sensor is only a calif thing. It does not show an A/f sensor application for anything but calif. models.
So that means I have two O2 sensors, 1upstream of the cat and 1 down stream, yes?
Just don’t want to order the wrong stuff.
Downstream Bank 1 Sensor 2 is DEN 2344154
Upstream Bank 1 Sensor 1 is DEN 2344161
Approximately $90 each from NAPA
seltzernator
