check engine light & "VSC off" blinking after installation or Eclipse 6600
I really need help!
I'm installing an Eclipse AVN 6600 in my friends 2008 SR5 V6 Non-JBL system. Its plug and play. All harnesses fit perfectly. Attached the vehicle speed sensor (VSS) wire (purple/red) behind AC panel. The radio and everything works, except I don't get speed pulse signal for navigation and also the Check Engine Light turns on as well as the VSC off light blinks. If I install the Original radio back in and unplug and plug the battery back, the warning lights go away. Could it be the wrong VSS wire that I tapped into. I read of many posts earlier with a similar problem after an aftermarket radio install. Any information would be appreciated.
I really need help!
