check engine light
FASTER-K9
My check engine light came on with the Trac lights comming on shortly after that. It still runs fine other than if you stop at a red light it idles a bit low and then when you go to give it gas it hesitates for a second and then its fine but the lights do not go out. I had the codes cleared but they return after about a day. The first code came up as code P0011(variable valve timing..VVT). Then once it was cleared the next time the lights came on this code and 2 additional codes came up (which i can't recall right now). Called the dealer and they said to check the oil and make sure that it wasn't to low or over the full mark as that could throw the lights on. I did check the oil level , as I recently had the oil changed, but it seemed fine, could someone please help! P.S. I have a 2005 4Runner V6 Sport Edition with K+N cold air intake, Gibson Cat back exaust , and UNICHIP installed. :roadkill:
