Check out the NEW Avalon!
Koz
http://www.toyota.com/vehicles/future/avalon.html
This info came from the Toyota web site.
All grades are powered by an all-new 3.5-liter, 24 valve, V6 engine matched to a five-speed sequential shift automatic transmission. A sequential shift feature allows the driver to enjoy a more involved driving experience by controlling gearshifts manually, when desired. Equipped with Variable Valve Timing with intelligence (VVT-i), and a dual-stage variable intake manifold, the new V6 produces an impressive 280 horsepower and 260 lb.-ft. of torque
The Avalon can effortlessly accelerate from zero-to-60 mph in 6.6 seconds while achieving an impressive estimated EPA fuel economy mpg rating of 22 city/31 highway.
The Avalon brings several "firsts" to the Toyota lineup. Side mirrors on the Limited grade feature Toyota's first "in-glass" LED turn signal, and a LED puddle lamp that illuminates the area along the side of the car when passengers approach the vehicle. The Limited grade also features side mirror memory.
Toyota's first low-profile wiper blade was uniquely developed for the Avalon. The wiper blade's aerodynamic, low-profile and lower sectional height results in efficient wiping and reduced wind noise. The one-piece blade assembly contributes to the reduction of frozen blades.
Touring and Limited grades feature high intensity discharge (HID) headlamps with dynamic auto leveling for improved visibility, while reducing glare for oncoming traffic.
Has one-touch auto-reverse power rear sunshade, driver and front passenger heated seat with fan, memory driver's seat, power driver's seat cushion length adjuster, and Smart Key System.
The front of the driver's seat cushion length is power adjustable, resulting in improved support and a better fit between the seat surface and thigh. Not only are the driver and front passenger seats heated, but they also feature a fan in the seat cushion and seat back that blows air through the perforated leather trim to improve driver and front passenger comfort.
The Smart Key System provides convenience and enhanced security for the Limited model. With the Smart Key System, an on-board sensor recognizes the signal from a light and compact key fob when it is in close proximity, turning on the puddle lamps and interior dome lamp and unlocking the doors when touched. Once the Smart Key System is engaged, the system allows the driver to start the engine by pushing the power switch. The driver can also position the key close to the power switch and push the switch to start the engine. Smart Key users do not have a conventional key to start the engine. The Smart Key System also allows drivers to open the trunk when the key fob is near the rear bumper.
Limited models also offer Dynamic Laser Cruise Control. The Dynamic Laser Cruise Control system detects slower vehicles traveling ahead and decreases speed accordingly, and maintains a pre-selected distance between the preceding vehicle. Finally, the Dynamic Laser Cruise Control detects when the preceding vehicle changes driving lanes and increases the car to a pre-set speed.
Both driver and passengers can plot a course with the available navigation system using an eight-way switch and scroll lever. The navigation controls have surface emitting illumination and hide away above the gated shifter. Maps, climate and select audio controls are shown on the seven-inch active matrix color display located beneath the center air vents.
The Remote Engine Starter (RES) is new to the Toyota brand and available on all Avalon grades equipped with the factory alarm system as a port- or dealer-installed option. Drivers may start the engine from a remote location by depressing a button on the key fob. After the engine has started, the climate control system will use the most recent settings to pre-heat the cabin on cold days or cool it down when the outside temperature is high. If the RES is used to start the car, the engine will shut off automatically for safety purposes when the vehicle is unlocked, after the doors are opened, when the key is inserted into the ignition lock cylinder, if the brake pedal is depressed, if the hood is opened, or if the shift lever is moved out of the "park" position. The vehicle must be restarted to drive away.
Koz
This new Avalon is very impressive. All of the features that I thought were exclusive to Lexus appear on this Toyota. For example: self-dimming side mirrors, memory seats, push button start/stop, HID headlights, HVAC controls on the steering wheel, rain-sensing wipers, all in one key, and auto sunshade. I seriously believe that this will give the luxury car brands (BMW, Mercedes, Infiniti) a run for their money. Now, if only they put 1/8 of these new features on the 4Runner, I would be extremely happy! Check out this little outline introduction I found online:2005 Avalon Introduction
on paper (specs alone), the avalon has EVERY CAR in it's league beat... haven't test driven one yet, but with that engine/'transmission combo, and the toyota reliability and quietness, who's going to buy a ford 500 or anything else? the avalon is rather cheap too, starting at ony 26 something...
2005 Avalon
I test drove the Touring Edition twice. It is very impressive. It's a new design and looks pretty nice, V6 with 280hp. Back seats recline and plenty of room. I got a price of $31,000 for the Touring. Very comfortable and quiet. I also test drove the Acura TL and IS300 but the Avalon seems the best buy for the money. Just my opinion.
