chevy colarado rims fit 4runner?
4runner269
A guy is selling some black d-window rims with 31 thornbirds with low tread for a fair deal. WIll these fit the 4runner? Not sure if the colarado's came with the small bore or regular size hole for the lockouts?? Tires are kinda wasted but would be worth buying for the rims. Not sure on backspacing yet. Thanks for the help guys.
If they are factory rims, the center hole is usually too small.
If they are aftermarket it shouldn't be a problem.
I hope your buying for the rims, not the tires.
I don't know about the wheel fitment, but those tires are just about junk even when they are new. However, they are Swampers. You could probably take a grooving iron to them, remove half of the tread blocks (to create more void area), sipe the remaining tread blocks (makes the blocks more flexible), and groove down into the carcass a good 1/8 of an inch. It doesn't sound like much, but I bet a Thornturd cut up like that would hook some dirt! Just for giggles, go and look up Aetna Cut tires. People go crazy with those groovers...
7ron
