Clearance issues!!
pelle047
a friend of mine is giving me a set of 34x11 buckshots. about 75% tread so im assuming 33.5" now. If i have a 3x2 cornfed, will they fit? I have an 05 sr5 2wd, any advice will help
Most likely they will not fit, at least not without some work. You will rub on the upper control arm and also the frame and probably the body mount as well. With wheel spacers you can probably eliminate the UCA and frame rubbing but will then have to trim a LOT from the inner fender liner, front bumper and still have to chop the body mount.
tuṣṭāva
