Clearn Corner Question
A lot of the members recommended this guy on Ebay. This is where I ordered mine from as well.
neondials on eBay
You can check out how they came on my build thread. Haven't installed them yet though, but they came with replacement orange bulbs as well.
I'm pretty sure there is only one aftermarket manufacturer, DEPO, might be wrong, so whoever has them cheapest is who I'd go with.
You could also look for an OEM set off a Hilux Surf.
I got mine from Burtman, more expensive but quality was great
Did you get "frosted clear" or "Crystal Clear"? Also, do the clear corners fit all years of the 3rd gen? It looks like on burtmans website it said that the "Crystal Clear" corners will fit 96-98's with upgraded 99+ headlights, is that a requirement to fit the "crystal clears"? the "frosted clears" dont say that.
What will work on a 2002? All third gen corners? Because the only ones he has listed (neondials) are 96-98 and 99-01
.... Haven't installed them yet though, but they came with replacement orange bulbs as well.
Install them! If it takes me only about 10 minutes to do it'll take you less time! I think it took a Phillips head screw driver and a plastic pry tool. You pry the light forward from two mounting studs after you remove the screw. I also have the neondials crystal clear headlights and corner lights on my son's Tacoma. They really update the 15 year old truck.
Instead of the flat screwdriver I use a plastic trim pry tool to prevent scratches:
https://www.youtube.com/watch?v=tPa_0vdGnmo
I am waiting for a day it isn't raining since I am going to Plasti Dip the grill while I am at it. Been raining almost every day up here.
Runvod
