Side Marker/ Corner Light
MBingham1998
So a while back I hit a deer and I think the impact from it messed my fender up, my corner light on driver side doesn’t line up with screw hole now, so until I get it fixed was curious anybody had any good ideas on ways to zip tie the corner light in? Where would be best to run the zip tie through?
I’m gonna use a dremel eventually and trim up a little of the lip between the corner light and the screw hole on top of headlight housing so it lines up, but until I did wanted a temp fix so I can at least put a light in it, the zip ties I have I tried to put through the top of headlight housing (screw hole the light goes into) but the zip tie wouldn’t actually tighten on it, it could just be the cheap ass zip ties I had so I may buy a bit more expensive ones to try until I take a dremel to it but wanted to post here first see if anybody had any ideas on it, thanks
I think you should try running the zip tie through the original screw hole on the corner light, and then either. Wrap it around part of the fender bracket or inner fender metal just behind the light. OR fish it around any existing holes or slits in the metal behind the headlight. If the zip tie slips or won’t bite, try doubling them: one tight to the housing, one looped through that
erinobr2000
