99yota4
Hey guys, I'm not sure if anybody even looks in the audio/electronics section anymore because I am not getting any feedback. I've posted similar treads on the12volt.com and I haven't gotten any feedback there either! So I just wanted to see if some one looking in the general discussion forum would be able to help me here.
The thread can be found at security, remote start, 1999 4runner
**I went back into the garage to finish this thing up and was hoping I would have some feedback by now.
I determined that because I don't have any other wires beside the power and ground for the key ring illuminator that I do not have a immobilizer on my 4runner. But before I can test the remote start operation, I need to figure out one problem:
I took H1/8 and connected it to the door trigger wire (Green/Black Driver kick panel) and also the Black front driver side door pin wire. I diode isolated them with the stripe towards the vehicle. I know I have to connect the other door pin wires as well but when I initially test the function of the door trigger I don't get any alarm. Meaning, I can arm the security, unlock the front door manually through the open window and open the door, and i get NO ALARM. What further confuses me is that I set the impact sensor to the most sensitive and shake the car and I get NO ALARM! The only thing that has triggered it so far was opening the hood. (hood pin switch)
In order to remote start I need to get this door trigger working so that I can get the system into programming mode and change the default Manual Transmission Start to Automatic Transmission Start. Therefore I get the 7 light flashes when I get the error message.
ALSO, when disarming the security with the door open, I get three parking light flashes. instead of 2. I get the regular 2 flash disarm when the door is closed. Can someone PLEASE HELP ME!!!!
Clifford 50.7x security/remote start in a 1999 Toyota 4runner sr5.
