Clifford 50.7x Install Help!
99yota4
Hey guys, I'm not sure if anybody even looks in the audio/electronics section anymore because I am not getting any feedback. I've posted similar treads on the12volt.com and I haven't gotten any feedback there either! So I just wanted to see if some one looking in the general discussion forum would be able to help me here.
The thread can be found at security, remote start, 1999 4runner
**I went back into the garage to finish this thing up and was hoping I would have some feedback by now.
I determined that because I don't have any other wires beside the power and ground for the key ring illuminator that I do not have a immobilizer on my 4runner. But before I can test the remote start operation, I need to figure out one problem:
I took H1/8 and connected it to the door trigger wire (Green/Black Driver kick panel) and also the Black front driver side door pin wire. I diode isolated them with the stripe towards the vehicle. I know I have to connect the other door pin wires as well but when I initially test the function of the door trigger I don't get any alarm. Meaning, I can arm the security, unlock the front door manually through the open window and open the door, and i get NO ALARM. What further confuses me is that I set the impact sensor to the most sensitive and shake the car and I get NO ALARM! The only thing that has triggered it so far was opening the hood. (hood pin switch)
In order to remote start I need to get this door trigger working so that I can get the system into programming mode and change the default Manual Transmission Start to Automatic Transmission Start. Therefore I get the 7 light flashes when I get the error message.
ALSO, when disarming the security with the door open, I get three parking light flashes. instead of 2. I get the regular 2 flash disarm when the door is closed. Can someone PLEASE HELP ME!!!!
Clifford 50.7x security/remote start in a 1999 Toyota 4runner sr5.
Hey guys, So I finally figured out all the door trigger wires!! Alarm triggers when any of the doors open! However, one of the rear doors is acting up. The dome light doesn't turn on when one of the rear doors are open which means it doesn't trigger the alarm. I tried following the wire back to the harness and there is nothing disconnected. I tried testing the wires for polarity and it is (+12volts) when the door is closed and it is grounded when open. I unbolted the "pin" and it didn't seem like anything was wrong. Can anyone help me figure this out.
My next problem is due to my inability to comprehend instructions on manuals. I want to RESET the remote controls to the DEFAULT settings because I messed around with it not knowing anything and I don't know what features I turned on or off etc.
The next thing after resetting the remote that I want to be able to do is Change the SYSTEM to "AUTOMATIC TRANSMISSION START" from the defaulted "Manual Transmission Start" I tried following the instructions on the install manual but I'm not getting something, so if anyone can explain it to me in a more detailed way that'll be great! Once that's done and the HOPEFULLY the remote start works properly right off the bat, then all I have to do is gather all the wires and mount the system and put everything back!! I feel so close yet kinda far from being done with this project. Thanks to all of you who've helped so far and thank you to those of you about to chime in your advice!
Zett
