Clock spring and steering column
JtuckerSvces
Ok so I did the steering rack and broke the clock spring plus the steering wheel is 180* out.
What turns the signals off? I noticed they have to go 1 full rotation for auto kick-off.
Can the steering wheel be repositioned on a splined shaft or is it a keyed shaft on only fit 1 way?
I use my horn daily and it MUST work. (Not road rage, just backing up and serious company policy)
Steering wheel is splined so your good there. Clock spring is cheap on eBay/Amazon and you can rent a steering wheel puller at Advance for free. Just did a new steering wheel and it took about an hour.
Don't even need a steering wheel puller, just a 7/8's (22mm) socket (I used my lug not 4 way) then put a hand at 3 and 9 and wiggle till it comes off, a shot of PB may expidite the process. To get the airbag off you need either a T25 or T30 torxs bit ,pop off the two little round covers behing the wheel but on the wheel body at 3 and 9 and back out the airbag screws. The screws are captive so they will not come all the way out. Then wiggle the airbag free. I like to have the battery disconnected and all power drained before I pull and airbag but YMMV. Disconnect the airbag from the Clocks spring and then pull the column covers, a couple of JIS screws, (3?) then the clock spring pulls off with four more JIS screws. The turn signal stalk and wiper stalk are attached to the clock spring.
What turns your signals off is a little spring loaded rocker arm that catches on the clock spring as it turns. Pushing the sigal arm up or down juts it out and then the rotation has a peak that catches it and returns it. Hard to explain but easy to understand when it's in front of you.
I recently replaced my clock spring with one that had the OE fog light switch on the light stalk.
AndiGarage
