Clunking noise from rear end, trac bar makes noise when tapped with mallet
thegipper
Hey guys, some of you may know my situation with the 4runner I just got from my bro. If you want to see the details, it can be found here
Anyways, I installed the rear suspension I got from Kurt (used springs and KYB shocks but in great condition) which immediately made a huge difference from the old blown shocks. There was a clunking noise which I figured was from the blown shocks. The noise is now mostly gone but it still makes some noise when going over rough roads ect.
I of course went under the rear with a mallet and some gloves and started pulling and tapping on stuff. Everything seems to be nice and firm (control arm/bushings upper and lower), *new shocks and so on.
The only thing that does make noise is the rear track bar (pan hard bar). When I tap on it with a mallet it makes a metal on metal noise. My guess is the bushing are pretty worn out. I also can push and pull on the bar and get some movement out of it. I would imagine that the weight of the vehicle really gets it moving when going over bumps. This also explains why the rear axle has a "loose" feel to it when I go over bumps or rough patches in the road.
I'm pretty confident this is the source of my noise. I did a search but I cannot find anyone that sells replacement bushings for the rear track bar. Do you have to buy an entire new track bar? Does anyone have any suggestions of how I can either replace the bushings or where I can get a replacement track bar for cheap? The scrap yards around here are pretty scarce so I'm not sure if I could even find a used one, let alone one that is in good shape.
Thanks for the help!
Cool thanks for the info.
So any tips on how to remove the old bushing and install the new ones?
Sent from my SM-N910V using Tapatalk
