Clutch Help !!!!
edeuce
Ok, my clutch on my 99( which has 293k on it no idea if clutch has been changed) has started acting up. Pulling up my drive way clutch starting shuddering real bad. Now seems to b doing more often. Taking off from light i cant put any load on clutch r it shakes real bad. So, my question is (looks like my clutch is going bad?) Do i get stock replacement R aftermarket clutch ??? What ya'll think ? Thanks
I got this Aisin Kit off Amazon.
Amazon.com: Aisin CKT-040 Clutch Kit: Automotive
Aisin is the OE manufacturer. Read the blurb and they state it is IMPROVED from the factory clutch. (It is slightly different.) I can confirm this clutch is as smooth as butter. If you would rather spend a lot more for a heavy duty clutch, head over to Marlincrawler.
I have that same kit installed in mine and it works great. You might want to look into a new flywheel as well, if it's got 293 on it it's probably in rough shape.
But if it's not too bad you can have it machined smooth again.
Ha, Durk smooth as butter ? That would b AWESOME !! Mind is hard as HELL ! I drive BMW's for a living an just bot put my foot thru floor now ! LOL Did u replace flywheel also ?
Yes, had to. Mine was cracked and could not be machined. NAPA had a great price ~$85.
Well. it ain't no Bimmer, but it's smoother than I remember mine when new.
Bunkstaff
