matto1kute
hey guys i just put a kit through my clutch master and slave but can get it to bleed. any ideas? its a 1990 4 runner with 22r in it
What was the original reason for installing the kits?hey guys i just put a kit through my clutch master and slave but can get it to bleed. any ideas? its a 1990 4 runner with 22r in it
i was driving home and when i put my foot on the clutch and changed gear it seemed that i hadnt put my clutch in the whole way but i had so i presumed the clutch master or slave was starting to die. u know how sometimes hydraulics gives u a little notice b4 it dies. well ive rebuilt them and i can see the slave pushing the fork when i put my foot on the clutch but the clutch doesnt seem as heavy to press as it used to be and it wont go into gear when the motor is running. ive measured the distance between the slave and the fork and when the clutch pedal is fully pressed the fork moves by 1.5cm. is that enough? im preety sure ive bled all the air out
Do you have any "free play" in the pedal? there should be some before you really are pushing the master piston.i was driving home and when i put my foot on the clutch and changed gear it seemed that i hadnt put my clutch in the whole way but i had so i presumed the clutch master or slave was starting to die. u know how sometimes hydraulics gives u a little notice b4 it dies. well ive rebuilt them and i can see the slave pushing the fork when i put my foot on the clutch but the clutch doesnt seem as heavy to press as it used to be and it wont go into gear when the motor is running. ive measured the distance between the slave and the fork and when the clutch pedal is fully pressed the fork moves by 1.5cm. is that enough? im preety sure ive bled all the air out
