4runnerRob95
Hey everyone I'm new to the forum, thanks for any help in advance. I'm currently having a problem with my '95 4runner V6 5 speed, she has 240000 miles on her and is still running strong! Except that right now I'm unable to shift gears.
Symptoms:
-If I start the truck in natural It starts fine but when I go to place it in gear I'm not able to push the stick into any gear no matter how hard I try (two hands pushing).
-If I start the truck in gear (say first) it will start but will begin to buck forward unless i hold down on the break. Once started the truck will run fine in first but will move forward with the clutch to the floor.
-The transmission shifts gears fine with the engine off.
-The clutch feels softer then normal, but does have pressure.
The entire clutch was replaced at 200,000 miles including master and slave cylinder.
I have already tried replacing the slave cylinder and bleed the system, but am still having the same symptoms with no improvement. Thanks again for any hint tips and help.
Symptoms:
