Coil spring spacers
Jhacker1
I need to fix my rear end sag. Researched some coil spring spacers and i decided they will be my fix. Can anybody recommend some that ain't to expensive or some good brands. Any pics of them in action would be appreciated too.
Thanks!!
i put some 2.5" on mine and it made a world of difference. they are fairly easy to install. there are 3 types, plastic, aluminum and polyurethane
plastic: cheap, but have been known to break after a few years. cost 70-75 a per set
aluminum: expensive, but bullet proof, never sear down. i have heard rumor tho that they squeek after a while. 100 dollars a set
polyurethane: my favorite, they are strong, dont squeek, they are a hard rubber so they act like a second bump stop too. cost about 90 a set.
if you have any questions or need help installing them just post up i'll follow through, they are pretty simple tho. i would highly recommend renting a spring compressor from autozone (it's free) the can be installed without, but it's a PITA.
You mentioned inexpensive and good brands together. Keep in mind that those two don't usually mix. However for a quick fix, maybe a year or so, and you are not doing heavy off roading here is some inexpensive one. These run from 7 to 15 dollars. Some of these require the spring to be removed to install and some don’t. Also be sure you find out if they are for the front or rear as not every kind will work on both.
Discount Auto Shocks - Auto Shocks at Wholesale Prices - Coil Spring Spacers
Here are some more expensive ones.
http://www.summitracing.com/search/...-Polyurethane-Coil-Spacer-Lifts/?autoview=SKU
http://www.dailymotion.com/video/x9216z_how-to-install-a-daystar-spacer-on_auto
Thanks!!
What ones have toy looked at so far?
those cheap ones from autozone are no bueno, the bolt style i had initially. they lasted about a mile down a light trail before wobbling loose and falling out somewhere along the way. the rubber one thats a circle does work, i had a set of those one for months and they lasted all the pounding i threw at them.. the only reason i took them off was because i bought some real ones. but dont have too high of expectations for them. i jacked my truck all the way up to decompress the springs, and sprayed them with water and dish soap to make them slippery and slid them aaallllllll the way down with as much as i could annd i got .6 inches of lift from it.
Im actually looking for the same thing.. where would you get the polyurethane ones? local auto parts store? also with the 2.5" did you have to switch out the shocks?
Daystar KT09108BK Comfort Ride 2.5" Lift Rear Coil Spring Spacer Kit $129.95
Daystar KC09103BK Comfort Ride 1.5" Front Coil Spring Spacer Kit - ... $39.95
Through amazon
Is this a good set up?
You can get new Moog springs from Amazon for about $75. Might as well just fix the root of the problem.
