WhiteLightning
I've done my best to search for similar issues, to no avail.
When my '15 SR5 (suspension info in signature) is exposed to sustained cold (<20F) a loose clunking develops, which is worse at low speeds over bumpy surfaces. At times, it sounds like something is going to break off from under the vehicle. Passengers have said that it sounds as though it's coming from below front passenger side. From driving position, it sounds as though its coming from passenger rear. I've brought it in 4 times now and they can't ID the issue. I was convinced to replace 5100s in rear, did not fix. I've personally gotten underneath and looked and there are no glaring abnormalities.
I'm curious if anyone else has experienced this issue, and if so, what the solution was.
