Color matched grille - done with pics
KellyJ
So I finally got around to color matching my grille to the rest of the front bumper - decided to go all silver with a black emblem. I am just sick of the chrome to be honest. I plan on changing all the rest emblems over to black this week, after my classes start up again. Also got rid of the baffles for the horn so now its mad loud :happy bda
I'll get up better pictures in the AM or when I get some time tomorrow
i'll give you an A+ for everything but the paint match ... looks a little off to me. Of course having two MSM vehicles, i'm a little overly critical of the paint match on those lol
It looks off like that because it was still a little wet when I put it on (anxious to put it on :bash: ) , and its hard to tell at night the differences... but tomorrow morning it should look a bit better. I had the same reaction right after I installed it.
got any details on how you did it? did you sand it any or use any kind of primer or clear coat when you got done? i'm gonna paint my chrome one black so you doing yours comes at perfect timing! looks great to by the way :D
Yeah man, it's really simple actually- easier than I thought it was gonna be. The part that takes the longest is probably waiting for the painted parts to dry and being patient (which is hard for a kid with ADHD to do haha)
You'll need the following for the mod:
1. Silver spray paint (I used Duplicolor, unfortunately not the exact match for my Millenium Silver, but it was close enough for me)
2. 300-400 grit sand paper. I sanded all the surfaces for a good fifteen minutes
3. I used compressed air to make sure all the dust that remained after sanding was cleared. Not essential to the process but it helped :)
Here's how I went about it:
Disconnected what was remaining of the tabs behind the grill that connect the grill to the radiator support. I used an extra long flat head screw driver to reach the bottom tabs. They are pretty fragile so watch out
Sanded the grill and removed Toyota emblem which is held on by 3 Phillips head screws
Sprayed both parts with an air compressor to ensure they were clean
Put on 2 coats of the spray paint with about 20 minutes of time between each coat. Finished up with a coat of clear gloss
Painted the emblem with a flat black (2 coats once again), then finished with a coat of clear gloss. Sort of achieved a black pearl effect. I plan on doing the same treatment to my other emblems soon
After everything dried, I screwed the emblem back on and remounted the grill back on the truck. Done and done.
Good luck with your grill Sloan and post up pics when you're done :bigok:
PS- make sure you got some tunes too - I was jammin' to FM on that 20 year old radio haha
The baffle is the metal piece under the horn on the left in this picture. I had already removed the right side one Its just a thin piece of metal, easily wiggled back and for and it'll eventually fall off leaving a clean edge :artist:
painted
why didnt you match the exact color -in a hurry? but does look much better., good job.
Re: Re: painted
Clemsonfan15 said:
Probably because that would have cost a lot more.
Sloan- I think he used Duplicolor.
Well put Clemson. Today it looks so much better. I'm in class right now but I'll snap a picture when I got out to the parking garage later and post it up. I can't justify spending a substantial amount of money on color matching exactly, because that would probably require some blending in with the bumper. And like I said, it looks 10x better in the sun and now that it's fully dried. There's only one run spot which isn't too noticeable. And yep, all I spent was $5 on the 5 oz. can of Duplicolor paint- everything else (flat black spray paint, clear gloss, sandpaper, air compressor) could be found in my garage, aka free (cha ching)
$5 and 2 hours of my time well spent I figure:)
Fo_SheeZy said:
Looks good, definitely a huge improvement!
Thanks! It was noticeable enough for my parents to notice and comment on it too. I was surprised when my mom said "It looks so much better now!"
i saw it was duplicolor but there is like a ton of different kinds. like would the kinds specifically for cars work best? or the stuff that goes on better with plastic?
I went into Advanced Auto Parts and there is a huge wall of spray paints. All of them are for automotive applications, just like my can of Duplicolor. I think it was just labeled as Metallic Silver, and it matches Millenium Silver pretty well. I'm just about to head out to the garage to take off the rest of the badges and black them all out. I'll get pictures of them and of the grill while its still light out
Thanks for the compliments everyone. It's definitely worth the effort if you had the same thing in mind :cool:
