Connect Fog Lights to my Switch Panel?
The factory fog light switch only works when the headlights are turned on. They don't come on during switch accessory or when the high beams are engaged. So I can assume that I can unplug the factory harnesses and run power to them from my auxiliary switch panel? Does this sound correct? If so, where do I get the factory wire harnesses to plug into the factory fog lights?
Thank you all in advance!
-Mike :usa2:
I have my fog lights hooked up to my switch panel, fairly straight forward but I did end up cutting the stock wires. I can post pics when I have my car back
There’s a 4th gen mod where the fogs work independently of the headlights. I don’t know if there’s a similar mod for the 5th gen.
The Brite Box is what I have on mine. I do a lot of backroads, early morning driving heading to fishing spots. The brights combined with Diode Dynamics SS3 fogs make a massive difference in spotting deer on my way to the lakes. Very easy to install. I just did the fogster option if I remember. If I want the fogs off, I turn them off like I normally would on the factory stalk.
What kind of plugs do I need that will go into the back of the factory fog lights?
I left the stock plugs in, cut the power wire and re ran a new wire to the panel unit under the hood.
Ascole,
Hello, I'd rather just unplug the factory harnesses and purchase new ones for my switch panel. If I ever sell the vehicle, then I can revert my ride back to the factory switch.
-Mike :usa2:
Just an FYI, in most of the US it is illegal to run your high beams with your fog lights on while on public roadways. Not an issue if off-roading, but something to keep in mind.
Bombguy,
Thank you for the heads up, didn't know that. I think that is strange, because if oncoming traffic comes over the hill, I'm going to go back to my low beams, interesting! I plan to eventually go to the DD Pro's or Max's for my Fogs, but for now, I'd like to get it wired independently.
Be Blessed!
Also if your state requires annual vehicle inspection, check lighting requirements. Most states do not allow more than 4 road legal lights to be on at same time. This why fogs turn off with high beams as when high beams are activated high and low beams, total of 4 lights, are illuminated on the 4runner. If they find you can turn on the fogs with high beams illuminated they can fail you.
And disabling the fogs just for inspection probably won’t fly either as typically all installed lights have to functional to pass inspection.
chasebradshaw
