Constant vibration
Alright so when I'm driving my 4runner there's a constant vibration that's nothing crazy but it is noticable but gets very bad when you press the brake it also pulls to the left when braking its not the alignment as it drives straight when you let go of the steering wheel to see my guess is maybe warped brake rotars but I just replaced them just over a year ago now but I dont think that would cause a constant vibration when just driving also the vibration is not noticeable until you get to about 20mph
Sent from my SM-G930W8 using Tapatalk
Possible rotors still. If one caliper is stuck, it could overheat and eventually warp again. Feel your wheels after driving. The stuck caliper wheel will be super hot.
I was considering this as well as I just replaced a caliper a year ago
Sounds like it may be one of your wheel bearings. Is it a "Humming" noise coming from the front or back? Try to isolate it to 1 of the tires.
If you can get the truck up on a jack, try to pull push on the tire to find any "play". If you find it, it's a wheel bearing.
Alright guys I think I figured it out most definitely a stick caliper which sucks as I just replaced it 2 years ago completely ate the FR brake rotar and pads [emoji52]
tuṣṭāva
