Can anyone tell me if the lower control arm bushings are identical or are they two different parts (front bushing is different than rear bushing on the front lower control arm for the SR5 model)?:hatsoff:
Toyota lists different part numbers for the front and rear bushes, therefore I would say they are not the same. I do not know what the actual differences are.
Do you mean front lower control arm or A-arm?
If this is what you mean, they are all the same, the 4 of them (2 left and 2 right).
48061-35040 OEM Toyota BUSH SUB-ASSY, LWR A
The bushings for the front upper control arm are different from the lower ones, but still, all 4 of them uppers are the same.
48632-35080 OEM Toyota BUSH, UPR ARM
I have just replaced all 8 bushings and also both upper and lower ball joints, and man, what huge difference that makes to the ride.
Regards,
Gustavo.
Toyota shows that there are two different part #s for front lower control arm bushings, however, all aftermarket bushings show the same bushings in those control arms. I'm still confused!
Sorry for the revival...
What are the actual part numbers for Front UPPER control arms, front and back bushing? Toyodiy lists 48632B-35080 and 48632A-35080 but I can't find these online (Partsouq, etc)
Can someone confirm?
You have the option to go aftermarket if you want. Whiteline makes poly bushings for our LCAs. Here's a link:Front Control Arm Bushings - Toyota 4Runner - W53377A
He's looking for Uppers not lowers Tim. The Whitelines listed are for lowers. That's what I have installed. I'm also Using SPC uppers.
I hesitated to ask here, but it's still related, and could be helpful.The Whitelines listed are for lowers. That's what I have installed.
Did you notice quite a bit of increased road noise with your Whiteline bushings? I know poly always has a higher NVH level than "rubber", but it was more than I expected.
