Contura V Switches: Wiring Dependent LED
TiN
Looking for some wiring help from those with Contura V Rocker switches. I have a fairly good grasp on how this switch should be wired, but have run into an issue... My wiring harness has three connections on the switch end: 2 halves of the relay circuit and 1 for a switch light (12v). I have the 2 halves of the relay circuit connected to pins 2 and 3 (see wiring diagram below), which does in fact trigger the relay. I also have a tapped source feeding into pin 8, and pin 7 connected to chassis ground (this illuminates the switch's upper-independent LED). My problem is related to the switch's lower-dependent LED (Pin 3). The relay doesn't appear to send enough voltage through pins 2 and 3 to illuminate the lower LED.
Does anyone have a solution to this?
2015-01-1020_44_15-wwwotrattwcom_wiring_G66pdf_zpseefdd093.png~original
