Cooling system flush
runrunner
Okay, I have green coolant in my radiator and I just bought the truck. I was going to flush the system and replace with the red.
How does one do this to get all the old coolant out? The only time I did something similar was with an old Jeep Cherokee I had and I used the prestone flush kit where you split one of the heater hoses and attach your garden hose to it. Is there any other ways?
Do I need to flush the green stuff out or is it okay? I've read that some say its fine and others say no.
Flush the green out. I also had to do mine cause it was mixed (red/green) + there was corrosion in some lines. I have to do it again cause my heater core was clogged and didn't found out till winter.
So what i did was pull drain plug from radiator, disconnect bottom radiator hose and take you thermostat out. I also disconnected my outlet hose to my heater core.
after most of coolant is out, cap ur drain plug and connect thermostat, i then used water hose to fill radiator and use lung power to blow into radiator until i see clear water coming out of heater outlet hose. It took about 10 minutes to blow out the water/old coolant. Know it sound wired, but it worked and i will be doing it again.
For your clogged heater core you might want to try this more direct approach, (particularly post #8 and on).
http://www.toyota-4runner.org/3rd-gen-t4rs/63149-trickling-water-sound-heater-core.html
