Alright its installed. I don't know exactly how long it took but I'd say around 8 hours and that includes two trips to AutoZone (first trip - floor jack, spring compressor, new metric wrenchs; second - air ratchet), watching a bit of the game and snacking. I wasn't really in a rush, but did want to get it completed before it got too late.
The install went fairly well and was not that complicated. I probably spent a good hour or two just trying to get the damn coilover bolts lined up correctly. So here is my cornfed write up...
REAR
Install went fairly quickly. I put the floor jack under the rear diff and jacked it up and put the floor jacks under the frame as recommended. After disconnecting probably more than I needed including the brake line holder and with the floor jack under the rear diff, I jacked up with opposite side with another jack to push the other side even lower. At this point the spring basically falls out. As I was the only one around, I installed the spring compressor and put the spring back into place with the spacer above it. Using the air ratchet I let the spring compressor out and then push the spring into place. Then put everything back together and then put the wheels back on.
FRONT
I started by trying to figure out where to jack and where to put the jack stands. I ended up but the jack stands on the high frame rail and used the floor jack later to assist with the coilover lift. IMO removing the front sway bar is a two person job and I definitely recommend disconnecting the point under the wheel well first. The rest of the take apart was fairly straight forward. The 3rd bolt in the back of the coilover was a big pain in ass and I ended up tearing my gloves. The XREAS disconnect went well and I dropped lost about 2 drops, 1 on each side. I removed the entire coilover and put the new hardware and spring compressors on while it was on my work bench. I don't see how you guys did the install without removing the entire coilover. That just sounds painful. The reinstall went well except for the number of times I had to adjust the top plate to get it aligned with the frame.
RESULTS
The truck looks great.
NEXT QUESTION...
So now that I've saved 400 bucks on the install, my question is should I get the alignment before or after I install the Spidertrax wheel spacers??? I figure I'll order them tomorrow and I've heard the turn around is pretty quick with them. Thoughts?
