Cornfed Users..
BlkSS1755
does anyone have a pic of this? it's #17 on the instruction sheet. my instruction sheet wasnt included.
17. Align two of the top mounting bolts parallel to the lower mounting bolt centerline for alignment of assembly during re-installation. See Drawing on back.
thanks
thanks
I hope you found what this means by this time. If not, this just means that you have to align two upper bolts for the mount with your lower shock arm, so when you installing it back the shock will be in correct position.
