Cost to Install Bilsteins?
apache67
Hi Guys,
Looking to replace a set of stocker shocks with some Bilstein 5100s (5th Gen 4WD with KDSS). Just the shocks not the coils.
What is a typical cost to have a Toyota dealership install them?
I understand an alignment is recommended as well with getting shocks replaced?
Thanks much!
G
I did mine myself but I have seen rates around the $400-750 area depending on who you ask + about $100 for an alignment.
I would not have a dealer do the work only from a cost standpoint… it’s a pretty straight forward job and most any mechanic can knock it out.
Ouch! That's a hefty cost.
Put out a "feeler" for a good 4x4 shop in the SLC area.
G
Hi Guys,
Thanks much!
G
ProDemand lists the labor time for replacing front shocks w/KDSS as 3.7 hours and rear shocks (w/o REAS) as 1.0 hours. Plus alignment. I'm not sure what REAS is either. Depending on your area labor rates can be $60 to $200 per hour.
XREAS is a linked shock system - it would add a ton of labor to the job (and would be deleting the system if 5100's were installed). Available on the 4th gen+ 4Runners and some other Toyota body-on-frame SUVs.
-Charlie
-Charlie
That looks like a nightmare lol thanks for the info. I would definitely be deleting all that.
delislerebecca
