cost to replace timing belt + water pump ?
There are some awesome kits on eBay that use all Toyota genuine parts. And there are awesome step by step write ups on this forum. Save the money!
Hey guys I just bought the same kit that 111db got. Aisin TKT-025 Engine Timing Belt Kit with Water Pump. I also ordered a new thermostat,crank bolt and belt set. It does not come with the crank or cam seals. The 2000 4Runner has 150k on it. Do the seals usually leak? I believe this is the original TB.
I just did mine and they were not leaking and I did not replace them either.
I shopped around between about half a dozen shops. I had all the parts to do it myself and replace pretty much everything (see list below). I literally turned the first bolt and thought "wow, I really don't feel like doing this). So, the shop I ended up going with charged me $350 for all of it, but several were around $500-- kn Northwest Florida, heh.
Radiator
Timing Belt
Water pump
Thermostat
Cam / Crank Seals
Oil Pump
All new hoses
About $890 at a local dealer. Just had it done and I was overdue. I get a loaner car too! They gave me a 2018 SR5. The service rep knows I like 4runners and he is a member here but I don't know his handle. Thanks Brandon.
I was just quoted $1700 from a local dealer, but I think the service writer isn't familiar with the job and quoted me as if all of those items are separate jobs. I'll update after I visit the shop today.
Sent from my SM-G900V using Tapatalk
Here’s a breakdown of what I got at and indie for $990 in the end:
I would ask if you can provide the parts. They are seriously upcharging you on that Aising timing belt kit. That kit is 175 bucks from Amazon. Plus it looks like they are using aftermarket cam/crank seals which I would highly suggest you don't let them do that.
Even the aircabinman kit on Ebay that has everything on here (all OEM) is only like 270 bucks. You would just have to pay for their coolant which doesn't look too bad at 20 bucks a gallon. And I would hope that they would not be putting in "reconditioned" antifreeze, whatever the hell that is...
I had my timing belt and water pump done with asian kit for about $1,000 by an independent mechanic here in the Denver area. I also had my cam seals, thermostat and my crank position sensor replaced at the same time.
AISIN kits on rockauto are all OEM supplier parts. My V8 was shipped for $175, master toyota tech $150 including installing new spark plugs....hard to beat!
Instead of paying a boat load of money for this job, do it yourself.
These 2 videos will show you how to get it done. Make sure to watch Part 2 because we show a much easier way to get the belt on and share other helpful info. Also, read the video descriptions and comments we have pinned because there's helpful information in both those places too.
<iframe width="560" height="315" src="https://www.youtube.com/embed/vHC46ypHxWc" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
<iframe width="560" height="315" src="https://www.youtube.com/embed/mErd7xoBS9I" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Like everyone I used Tim's excellent videos for this job. The only possible thing I could add to the great tips and tricks he offered is in regard to positioning of the crank when you go to put the timing belt in place.
Normally you would set the crank and cams to Top Dead Center (TDC). You would then align the marks on the belt labeled left and right cam with the marks on their respective pulleys. But when you attempt to stretch the timing belt onto the crank pulley, you can't pull it tight enough to get it on the proper teeth. It often goes wrong here. From the moment the crank spins the first time it takes up the slack on the non-tensioner side and now you're off a tooth.
After three tries I finally decided to spin the crankshaft and purposely have the crank timing set almost 1-full tooth before TDC. That means you can easily get the belt on and by the time the slack is taken up, the timing is correct. Be sure to spin the engine over by hand several times and triple-checked the alignment of cam and crank timing remained correct.
I have a complete list of parts needed here: Kit
I did a price list with both discount online Toyota parts suppliers and Amazon and found that after free Amazon shipping was considered, it less expensive to order from Amazon EXCEPT for the valve cover grommets if you happen to be doing the valve cover gasket job at the same time.
I picked up the $300 kit from aircabinman and my brother in law will be doing the work at the dealership he works at for $200 in labor.
