hi folks,
hope that everyone has had a great weekend.
so, i just bought my very first 4runner last week. so far, i really like it.
trying to get all the maintenence caught up. it was due for an oil change and needed an air filter so i started with those. obviously air filter was pretty easy. then i went to do the oil. drained fine however getting the filter off really kicked my ass! tried going at it with some of those big oil filter pliers from underneath with no success. then tried going through the wheel well under that little flap. could get my hand on it but thats it. it was tight and i couldnt get a great grip. finally decided to take off the drivers side tire to get a little more room to get after it. took the lugs off but couldnt get the tire off once jacked up?? luckily i figured out that if the wheels are turned hard enough left you get a little more room and can get the filter with realitive ease. so, finished up the oil change and i suppose it went well. no obvious leaks. put in 5.2q but the stick still looked a little low so i add about another 1/3q.
so, my questions are:
1) is the extra 1/3q gonna kill me (my engine)? or just let it go?
2) is there any special trick to getting the tires off?? took the lugs off and the center cap and pulled on it and it simply felt "stuck". didnt want to get after it any harder since i wasnt sure.... i would like to get the fronts off to take a peek at the brakes so i know about what i am working with...
3) jack points - any special jack points on the 4runner?? can you just use that big shield underneath?? i ended up going by the short arm and hope that was okay...
4) i would like to change my fuel filter next. looks very straight forward but i have read a couple of thread where people are talking about the "compression fittings nuts" leaking?? is there anything special about changing or tightening the filter back on?? just take the old one off and put the new one on... tightly... right???
