First I want to thank all the active posters of the forum. I am a member of a couple forums, but no automotive forums because I'm just not a car guy. I know how tiresome it can get having new one-time posters like myself come in, ask their question, get their info, never to be heard from again. For every person that posts, their are probably 100 if not 1000 people that never post that are helped by the info you guys put out there. So THANKS!!
That said, I have a couple questions that I couldn't find the answers to in a search.
I am changing the pads on an '08 4runner. Pulled the front drivers side tire and saw the outer pad worn down to about 2mm while the inner pad was at about 5mm. I immediately think I must have a stuck piston as is apparently common on these. Pulled the passenger tire, and pads are worn, but even. Since I had already ordered new Akebono pads I figured I would just wait until they came before checking for a stuck piston.
Got the pads, started with the Drivers side, and to my surprise, no stuck piston. So I button everything up after dropping in the new pads and move on to the passenger side. What do I find? A stuck lower inside piston. So I put back the old pads and button that side up. So here are my questions.
1) Am I ok driving (I can keep it light if I need to) with new pads on the drivers side and old on the passengers side for a week until I get the parts to replace the piston?
2) Should I be looking for or doing anything else on the drivers side that would have caused such an uneven wear in the pads or am I good to go?
3) The new Akebono pads came with a shim already on the back of the pads, but different from the 2 part OEM shim. Manufacturers instructions say to take the protective film off the shim before applying Moly-lube between the shim and back of pad. I dont see anything on the shim. Question is, does this shim replace the 2 part OEM anti-squeal shim, do I put the 2 part OEM anti-squeal shim on top of the new shim, or is this shim in fact the protective piece they were describing, and I should pull it off, discard it and put on the 2 part OEM anti-squeal shim? (Drivers side currently has all 3 shims stacked. Rotor still turned fine without contact, so I figured there shouldn't be any harm)
4) After replacing everything and going inside to pump the brakes, after a few pumps I got an audible tone along with the ABS, traction control, and one other light. Tone and lights went away after about 3 seconds. At no point did I open the master cylinder or bleed screws, so there shouldn't be any issue. Was the constant pumping just triggering some sensor, or is there something I should look for?
Sorry for the long read. Thanks again for all your help. This site helps countless people that never join or post.
Scott
Scott
