Couple things after sc install
Looks like you've got your problem taken care of. But if you still want to take a peak at your AFRs, you can look at your front O2 sensor readings. You've got Cali emissions, so you have a wideband O2 sensor up front, and you can look at the voltage it reports to see what your AFR is. Check out the write up in my signature for more info. If you don't have an iPhone you can do something very similar with Torque on an Android phone.
Yeah, so here's the deal with that... So I def want to monitor the a/f ratio's, but for some reason I can't get my scan gauge to display them... I did replace both o2's a few years back, and I used urd's guide... No codes popped up... But for what ever reason I can't get the scan gauge to display them... I'll look at your write up, but if the scan gauge can't, then most likely others methods won't work either... More investigation needed on my part! Thanks for your input though.
Scangauge is a little different animal as far as adding custom formulas go. It's all in hexadecimal, most of which goes over my head.
