Coverlay dash cover. Anyone use?
OCMike
Trying to find a way to fix my cracked dashboard. I came across this company and wondered if anyone has used their product? Seems like a pretty easy way to fix the cracked dash. They have 3 different shades of gray though and I don't know which shade will match my gray.
87-94 Toyota Truck and 4Runner 11-794
Mike if you need a new dash panel i can scavege the yard when i go.
up north our dash panels dont crack so let me know what color you need and ill see if i can get one for you.
I could use a tan one for a 2nd generation. Mines all cracked up. I would appreciate it if you came across one. Front arm rests as well. :guitar3:
Thanks a ton.
Plus 2 on that Tan/Oak dash cover for a 2nd gen, been looking for 6 mos and haven't come across one yet. :-)
Look what you got yourself into, Bad. LOL If you come across a gray dash cover, and the price is right, I may take it. Or maybe I'll meet you at the salvage yard next time I'm visiting my parents in Cedar Springs.
Check out my build thread. I fixed my dash pad and it came out well with the exception of a bad color match.
Just an idea :)
Keep me in mind for a 1st Gen Pass side Grey as well please. Maybe Kid could grab mine when he gets his and then I could grab it from him in OCT on the Moab trip.
Kid would this work for you?
Eh? BV is in Michigan, if he finds one for me I'm going to have to pay him for shipping.
Looks good. I might just have to look into that option also.
If you do I would approach a tad bit different. After you smooth and fill in the cracks, coat the whole thing in some resin. Dilute the resin with a little bit of acetone. I normally use about one tsp or acetone per ounce of resin. That helps with the soak through and it also extends the pot life of the resin a little bit. After you coat the whole thing in resin, lay some grill cloth (real thin stretchy material) over the whole dash pad. This will add a new layer of skin that won't crack. Then lightly sand and add texture and dye.
My method that I used in my build thread was a band aid fix. It will crack again eventually and then I'll do what I suggested above.
SV_dude has the right idea fixing is easy you can even strip all the vynal off and do a fiberglass dash!!!
But i will keep my eyes open for dashes!
