Cragar Soft 8's, with stock lug nuts?
Mulky
After some searching, I couldn't find a definite answer to my question. I just picked up a set of Cragar Soft 8 wheels today, and I was wondering if anyone knew if stock lug nuts will work with these wheels?
I plan on buying some black, aftermarket lugs soon enough. Just wasn't sure if stock ones would work for now.
The guy I bought them from had aftermarket lugs when they were on his 4runner, and he wasn't sure if stock ones would work either.
The bottom of the stock lug nut has a straight taper so you can use them with the steel spare wheel. If that matches the lug nut seat on the Cragars, then you're good (but they'll look funny with the shank sticking out). If the Cragar wheels have a curved surface to accept an acorn lug nut, then it won't be safe to use your stock nuts.
A set of non-shanked lug nuts is $20-$30, why worry about the stock 4Runner lug nuts?
