check out www.supracharged.com they can and will help with supra swaps. the 1jz and the 1jzgtte is a snug fit, but the 2jz will be even greater, as its a 3L insted of a 2.5L and if you go single turbo (2jzgte) it will be an even snugger fit. if ou go sequentail turbo, (2jzgtte) then you will most likely be modifying your engine bay, or fabricating new turbo downpipes, relocating waste gates, and other tedious tasks. might i suggest looking into a 7mget? its the motor yota put in the 87-92 supras. inline 6 3L turbo. the 7mge, the naturally aspirated version, was offererd in 86-92 supra, and 89-92 cressida. the 5mge /5mget was offered from 82-85 supra, and the 6mge/6mget was also offered in that same era.the 7mget did have some head gasket issues, but by increasing the head bolt torque from factory reccomended 58 ft/lbs to 70 ft/lbs. the 7mget had 230 hp stock, but you could easily modify the forced induction system to make more, and install mild cam, port/polish, gapless rings, new bearing mains, etc etc to easily breach 300 hp.anyone wanting a whole arsenal of info can PM me. i just wish LCE made perf parts for 7mget
Tho there is water mixed with my oil is there anything I can do to save the motor I have(3zv i think) or is there anywhere I can get /order one for less then $1000?
