Cree's 2000 Limited Thread
Cree
Well, build thread #2. The frame on my SR5 decided it needed to go on an involuntary diet and shed precious metal near the lower control arm mount, so he we are. Which, amusingly, is really where I wanted to be all along. Obviously it's a Limited, and it's a factory locker truck.
Original
Now
Suspension
Front:
SPC UCAs
TRD/5100s
Toytec 1/2 top plate spacer
Mike's sway bar links - All installed
Spidertrax 1.5 spacers
Rear:
OME 891s
Toytec 5125 4Runner shock kit
PCK
Brakes:
231s
T100 Dual Diaphram 10in Booster
T100 ABS MC - All installed
SS Lines
Tires/Wheels:
Tundra Split Spokes
Ko2 285/70/17
Lighting
5 3/4 Daymaker LED healights (Hi and low beam)
Rigid D2 DOT Fog lights
Optilux Super yellow Xenon in the factory housings
Misc:
Addicted Tube Bumpers
MJT Aux Fuse Panel
Modified corner lights
1st Gen Roll Bar
Bluetooth
SR5 interior (because screw leather in the summer time)
Mostly a Mall Crawler, with the ability to do more without having to change things down the road. Nothing special really. Just sharing.
Very nice! Always liked white/silver trim and white/white. Luck and enjoy the runner!! :cowboy:
looks like a great start, ill be curious to hear how different the brakes feel
I'll be sure to update. I had the 231s on my SR5 and I always felt like the pedal was a bit soft ssn's that the travel sucked, even after a few power bleeds.
Busy few days. Everything minus sway bar links is on hand, so I started ripping into it yesterday. I LOVE what Toytec did with these shocks. Hopefully they ride smooth.
I'm hemmed up on a welder right now, but I had a Toytec panhard bracket laying around, so I tossed that on for the mean time. Fresh brake job rounds out the rear. Found a burnt up ABS sensor, so replaced that as well. 891s with no front lift sure makes it look line a Rat Rod!
Sent from my SAMSUNG-SM-G891A using Tapatalk
where did you get that top mount bracket for the rear shocks? Id like to add that to mine. would make installing rear shocks so much easier.
The clevis came with the shocks from Toytec. I don't know if they sell them separately or not.
You can’t just add that bracket to standard bilstein shocks meant for a 4runner. I believe those shocks are Tacoma shocks with that adapter so they are compatible with the 4runner mounting location at the top. Correct me if I’m wrong @Cree
I had them with the 8” Bilstein 5125’s I bought from Toytec that are not model specific since they are eye mount style, not stem mount style like 4Runners use. I could never get the adapters to stay tight, even using the lock washer they come with. Lots of people run across this issue. Ymmv.
Edit: They are sold separately as well if you wanted to buy some.
You are correct. Double eye instead of eye and stud.
So the T100 booster and MC are MOSTLY a drop in job. Thought I'd sneak that stuff in before it sits 5 inches higher in the front. Had to pull a couple extra lines out of the way to get the bigger booster to drop in place. Also had to rebend both brake lines. Reservoir is a direct swap. Be sure to measure where the pedal clevis sits on the old booster rod. I measured from the base of the booster out. Should be a good starting point at least. On to the front suspension!
Also, little Carolina squat action on the parts truck.
Since Murphy is a Dick, I'm still working on getting the front buttoned up. Passenger side is all done minus the OTE that I didn't plan for (pro tip: always plan for them).
Added some SS lines from Wheelers while I'm at it. I think this thing will stop. How well is the question.
Well. It runs, drives and stops. However, the ABS is very unhappy. I don't know if it's a system issue or if the upgrades don't jive. I never really liked it anyway so I'll just shut it down.
Pedal feel is amazing. I'm stopped in the first third of travel. Probably bottoms around half. Didn't try it yet with the sway bars unhooked so I'll have to update on emergency stops later. Good weekend worth of work though!
im not sure what the sway bars will do in terms of braking. they reduce left/right sway of the vehicle body on turns.
Nothing. It's just squirrelly as hell with out them and I don't feel like doing a max power stop without them, in case it decides to pull or something weird.
These bad boys just came in the mail....
Also getting some rear steer under braking. Not sure if the drums are out of adjustment or if it's a panhard issue, but its obnoxious.
SOOOOOOO.
Figured out the squirlley issue and the brake pull at the same time yesterday. I paid Midas to do the alignment. They didn't tighten up the otr like I requested they do, so the nut backed off the right side and it finally let go yesterday in a parking lot.
New ends and a trip to Toyota and it tracks straight and brakes beautifully. Guess that'll learn me too trust another shops work.
Also got these in today. Going to give the Load C's a try. Figured if they work for a Raptor, they should work for me.
Had some spare time today, went ahead and tossed the rear bumper on.
Got the wheels back and tires mounted last week. Turned out great
I'm not happy with the front end height. Gonna try a 1/2in top plate spacer, see if that levels it out some. Hope that'll do it.
Should be the last photo with the stock front bumper too. Going to get the AOR bumper mounted up this weekend. Not sure how I'm mounting it yet, but have a few ideas. Also going to redo all the lighting on the front of the truck. I had the budget retro fits in the SR5. I liked the distance they gave me, but wasn't thrilled with the cutoff or the side throw. I'm not interested in spending three to $500 to do a good set of retro fits that could still get me popped by the HiPo for not being legal. So, I've come up with a different plan. I'm just going to post pictures of what I have on the way for now.
There's a second and third part to this plan that I think you guys may dig. I guess we'll find out when I get it wrapped up.
seltzernator
