12guns
Ok, I installed my Powerslot Cryo rotors along w/ a set up Hawk LTS pads on the front of my 05' V8 Sport 4x4. I've driven around town on and off this week and can't decide if I like the new set up. I did have a frozen caliper, so I bought a new set of Raybesto's. You would think w/ a $600 set-up, I would be able to stand my ride on the front tires, but no.
I broke the pads in per the directions. First thing I noticed was the excessive pedal travel, so the next day I bled the brakes for a second time which helped slightly. Even after bleeding two more times to ensure there is no air left in the system, I still get quite a bit more travel before the brakes engage. I know the Cryo rotors are "harder" and should give a lot longer life, so maybe they will continue to "break in" with the pads and increase stopping power as I drive more. Hawk had instructions for breaking in their pads, but I'm certain they will continue to seat w/ the rotors the more I drive.
I won't be changing anything yet, but I did want to let you guys know how they were so far.
What would I change? If I could go back in time, I would stick w/ non slotted rotors, probably Napa. I'm not convinced that the cryo and/or slotted will give you anymore stopping power. The pad is where the shorter stopping distance comes from. If the Hawk pads don't get any better as I drive more, I'll give some serious though to upgrading to EBC Yellow Stuff pads, which should be the best of the best for good stopping power that will hold up under the heat of towing boats and such. My OEM brakes seemed more "sticky" than the new set up, but they would not hold up to the heat of hard driving or pulling heavy loads, hince going w/ the Hawk pads and cryo rotors. I'll update after some more driving. May even take the pads off and ensure they are clean-I noticed a few lines around my rotors like there may have been something on the pad surface when I installed them. Shouldn't make a difference, but it will give me a chance to check everything over.
