SKIDMRK
I know I haven’t updated my build thread in a long time, but figured this could use its own thread for someone else that might be interested in doing something similar. I know that the scangauge is a nice unit, but personally, it’s not for me. Yes, this option is much more expensive than most, but I have the same gauges in my audi and love them. I talked to my buddy Greg at Podi (a manufacturer of vw/audi gauge pod solutions Podi.ca | Gauge solutions for Audi and VW) about this project and we figured out what pieces were going to be needed to make this work. Ended up starting with a pod for a 2002-2005 Audi A4 for the Frankenstein pod.
Gonna take some cutting to make this thing work.
First round of trimming.
Cut some more off.
What we are left with.
Roughing up the top of the column cover so the CA glue will have a tight bond.
Roughing up the bottom of the gauge pod.
Drilled holes for wire passage.
The magic elixir. Gap filling CA glue and accelerant
Glue begins. (didn’t take picture of final gluing, but all gaps filled and secured)
First layer of filler (you can see additional areas where pod was roughed up for bond)
First layer of filler on back side.
First sanding
First sanding on back side
More filler and sanding
Initial high-build prime
After 2nd prime and sand (did lower cover too so that they would match)
At this point, just waiting for the primer to cure and a final sanding before the finish coat goes on. After comparing some finishes, the best option surprisingly is going to be black plastidip spray. Since the leather grain is all gone from the pieces, the plastidip will match the rest of the flat black panels in the dash. I will be sure to get pictures of the finished product. I’ve just been taking my time with this in my spare time.
Cut some more off.
First sanding
