What we did when we wanted something like this we would find an oem from another car, say a honda, because they where half size. This way you can fit a very large turbo in the front. But they didnt have outlets on both sides like that. These guys can make you something im sure
Most cities will have a local Rad shop that can probably make you something. They should be able to use a custom core and then slap some end tanks on it, either welded or crimped. Won't be cheap though.
Thanks! That is pretty much what I was looking for. I don't want to do a custom job or spend a lot of money. I'm using an old tractor engine to run a few things on the farm and a replacement for that radiator was $500 so something close to the dimensions and cheap is ideal.
Do you know if its 1 core or 2 core? For a tractor I would assume more than one. I don't know if you can search via dimensions at Summit Racing, but Im sure they would have something even if you had to call them.
