I have 03 V8 and drove from S FL to Minneapolis for the holidays. After a day or two in MN I noticed a spot of grease on the garage floor. Looked at the boots and noticed a clamp came loose. I likely caught it the day it happened. Took to Toyota dealer. They pulled axle and put a new boot on after cleaning and repacking.
I got home and was washing salt off truck and noticed some grease in wheel well. I look under the truck and notice the clamp on the boot they replaced was off. I do not think it happened on the drive home. It was a week later when i got around to washing the truck. So I drive to Toyota dealer in FL. They redo what was done in MN. Driving home on the interstate I notice a rattle, or more of a knocking sound from underneath in the front. It did not make this noise on the way there. I do not believe enough grease ever came out to cause damage to the CV joint as I think I caught it both times very early. I'm wondering if there could be something they forgot to tighten? It doesn't make any sounds over bumps, just on the interstate at 55mph and up. Seems more pronounced at higher speeds, 70 to 80. A little scary too. Any Ideas? I will be taking it back to dealer but I'm just curious if any one knows about what has to be taken apart to do this job that may not have been put back correctly.
Sorry this is so long and thanks for all ideas.
