Dash lights wont work!!!
4runnercaruso
i recently bought a 95 toyota 4runner and the dash lights dont work so i took it in and they said its the dimmer switch so i bought a new dimmer switch and they still dont work? what can be the problem?
punctuation is key.
Anyway, since you have a 1995, yours is older than ours, as this is a 1996-2002 forum.
If that happened to our generation, I would suggest checking for a fuse labeled TAIL. That controls the dash lights and running lights on the 3rd generation 4Runner.
I am unsure whether this procedure is the same for yours. I have a 1992 that I will go and check the fusebox on. I will edit the post if I find another solution.
the forum has a search function FYI. Also a simple google search for "4Runner dash lights out" would have given you the answer.
YO CHECK YOUR FUSES UNDER THE DASH!!!!!!!!!!! are your brake/running lights working.
same thing happened to me not too long ago. bad fuse.
