Dash Lights
jastad
Hello,
I have a 84 4 runner. I rounded a bend and my AT Temp light, Battery, Brake light came on all at once. Has theis ever happened to any one else or do you have anysugestions how to fix it? The truck starts and runs just fine. I also check to make sure the belt was on the alternator and there was enough brake fluid.
thanks
What do you mean you rounded a bend?
Check your battery voltage with a multimeter. With the vehicle off it should be about 12.5 volts or so, and 14 volts or so with the vehicle on. The important one is the 14 volts with the vehicle on. If you don't get that voltage with the vehicle on then you have a charging issue. That issue could either be a wire connection or a alternator issue.
