dash mount for phone - any feedback?
96Runr
Has anyone used this phone mount on their dashboards? Looks too good to be true...
I can get lost inside a paper sack with directions how to get out... thanks much!
https://www.banggood.com/Universal-...=hoo&utm_campaign=i-cea-ph-yus-us-car-pc&pp=0
I have no experience with that mount or style. Personally I wouldn't want anything blocking that much of my view either.
I use a magnetic holder from Amazon that was about $13 or so. I've used it everyday for about the last 6 months and it's as solid today as when I first bought it.
It holds my ZTE ZMax Pro which is bigger and heavier than an iPhone plus — without any issues whatsoever. It has never fallen and is very simple to slap your phone on and off since you don't have to mess with clips/clamps or other "squeezy-majigies". Plus it does not obstruct your view yet can be easily seen without moving your eyes much if using a map.
In the last pic you can see the magnet under the case because the case is clear. If your case is not clear then you won't see the magnet. You don't even need a case either as you can apply the magnet to the phone itself too.
https://www.amazon.com/dp/B00I608BJ8/ref=cm_sw_r_cp_awdb_Qi3izbHQRVR05
I have same style one but mine has a little thing that flips down that holds the phone so it doesn't fall of when there is a lot of vibration.
I wouldn't want it blocking that much of my view. I don't think that's a legal installation in California. If I recall correctly, they want it to be in an extreme corner of the windshield. Some peoples groups do seem to like them mounted directly in the center of their field of view :noidea:
Are we really gonna go that route ? Technically YOU ARE NOT ALLOWED TO HAVE ANYTHING ON YOUR WINDSHIELD. Not even a air freshener.
I have the Mob Armor Mobnetic Pro mount that is basically the same at the one mentioned above and mounted in pretty much the same location. Picked it up for like $25 at the offroad expo last year. It has been worth every nickel. It's nice to use as a GPS when off-roading and easy to select music or quickly respond to a text. Never once had my phone fall off the mount since the magnet is pretty strong. I highly recommend checking them out. I even bought one for my wife's car too.
Thanks for all the feedback guys... prob a bad idea
too bad... had so many great reviews
such as: До 6 дюймов держит телефон
and: Agradeço informação sobre a data prevista de entrega desta encomenda
my fav: ダッシュボードを挟む部分は40mmほど開くと説明に書いてありますが、開きすぎると付いているゴムクッションが当たらなくなるので実質30mmくらいでしょう スマホを挟む部分は88mmほど開いた(無理矢理開くと95mm開いた)のでその幅のスマホなら挟めます 挟む部分は樹脂で出来ているので滑り止めかつ傷防止になっているようです ダッシュボードに使用するものですが、日�
great China stuff... for 8 bucks, I think Ill order, hang it upside down it and mount it over my tachometer... even THAT can't be illegal, can it?
I didn't like any of the dash mounts I tried, but I really like this Arkon floor mount. It installs under the bolt that holds in the passenger seat.
Out of line of sight, very sturdy, out of the way, not too much cable to get tangled. $25 on Amazon.
2001ATL
