Dashboard light out
octanejunkie
Elite Member
The light behind my dashboard on the far left (Tach and Temp Gauge area) has gone out - and turns out, so did the center bulb between the two TACH and Speedo.
I've not crawled under the dash yet to look - is this an easy-to-get-to spot or nah?
If anyone has a guide or steps to reach/change it I'd appreciate, thanks!
If you decide to upgrade to LEDs (they're a huge upgrade btw), make sure to only buy from superbrightleds.com. The ones on eBay and amazon are absolute garbage.
That's the $50 link right there, thanks for that :thumb:
I'm kinda looking to stay stock, but with the work required to get there, LED for the most common lights would be a smart investment
Thanks fellas!
I price-compared and ended up ordering all the bulbs I need from superbrightleds.com - thanks guys!
Will post an update this weekend after installing them :)
Sent from my Nexus 5X using Tapatalk
JOB COMPLETE!
Armed with my order from superbrightleds.com, a Phillips screwdriver, a 10mm socket driver and a child's knife from Ikea I was able to access and change all bulbs - thanks to the info and support to the members here [emoji106]
This is on 2/3 dimmed/lit
NdsBWI5isp82IiHNSP9fy5XDqWwFMu9GVQRNE131U6telD35-2wa7Q85z2w9TFTjv_ra14sIL_hssuFgzGz4iHgt6TNlq20j0k-McOLOIVpyjWR7vHshfue8LQYgAgDy75U9OF-Jd6gmmk8IucstP6U3_-wK90TMOD1lZUB0lB6BJ0-y78TSXGotUtjeKzVm3cksuZ5E-aV1WhdIMs1b8ni3Sx8XJQEn4-ElHIevnqPOoCYQ5cC1_IMuuOFRNRTDnIkwlEu_cGnqm6zHpf21Cf7-_aCbHioTsLZR4Voi8Y1u7X-6pJT3NJimUw6f5n5eqKIlaV46eu7MZ29QfVkrpkpGddOuvtIRp_nuBZP3CPlzI1xaXFC5wOQp5peNLaOBgiETYzkC4xDAiaZEFLu2W5tRERuAlKrj6LWfllj1V3r_THzHGz5eMsT5qLazPXcZgoTpBF7r_QfA5jbliO_BoWYGKrGk2WHk7ajxZEEIOlbpY7j7U7jUTZSVXq0t8PeSedkgNaRb1jBqR5CpchbAn-M34YtMFr49CT7c-qcuEcJOkolqZUqUEmyJfSQkIW8rdNWibK_E9o9-Ob3NyQ9L24ziYIXv5fjy=w999-h679-no
Sadly my clock didn't make it to the proverbial summit with me, it won't power on with straight 12v, so I ordered a replacement.
One thing worth noting, the LEDs are polarity sensitive, so I had to trial-and-error about 50% - the ones tach and speedo 3 being the most cumbersome and laborious; but I managed it with patience and a methodical approach to not break or scratch anything.
This handy pic from Yodatech helped me, and although I didn't have the guts to remove the actual circuit board, I was able to swap #22 bulb under the board by removing all the screws and working carefully under it with a hemostat - I always have one handy in the toolkit :)
62aH097jFezPBvlpU-hBmDN8-IH1jf_MFV2CgQA50YrLJb9hzwuiKWm0AwtixKAYgxkUyisDrNBdvuDbv0vE75bP0jokTZcMqxsuEQkbGdie4JRpiwHX7KZFe5i0uYCWoXIr22PC7WQBCu_dacpk1lKdJalC4YuAft0sqbq0SH6p6ZaF3K_OVioY6QjNCkMjX_zriWbjI567gmUWeDzAtXzuh54OML5HfKvcwdGcimnKjyAXd87G68CJ7IgRloux24lby_kBpiRGwNUEKU943sHLPAcPzn15RvlA-uniEMiApI54TgqknG5ILAOVUVm-hyKff7McARzbM9FbS95NoVa-Yl1zHqbgPOBC5Da_hX1YQj-JlLK3xmb5tXJ810rYDvQfOLm4-E27sbIylqJoGcdopfi7dPGfqYhdiQa8l7vJ1GmmdEEmv4Fmj_tjRCMTj5Pp2zYyDCSSMGXP8RTjYdlRu4QYSeZ2mj6z0P-wDVuSTxWm7X_CK1ZpaqTrgPEY4qp1vhKDWtW4V_4zzO6_O51DwHAa2fyFE3-jv-41r8Z1zYIzk-WIM2zbOVYFQAxl8wI08v0Xfg27QL8sWcN_QL9scXIlWHhJ=w453-h679-no
Next upgrades are passenger and cargo domes to panels using these from ebay and the pesky cigarette lighter light (I just want everything to work).
Thanks again guys!
QUICK UPDATE
I ordered a replacement clock from eBay on Sunday and got it today. After a quick test to confirm it works, in it went.
I didn't check the springs/pins coz its working, but when it fails I'll solder the pins and be done forever.
Nice to have a clock for once.
seltzernator
