Dashboard Lights
theaveragejoe
Hopefully someone has had the same problems and can help me out with my dilemma - I realize how terrible it is to wish for such a thing, nonetheless. . . Just last night I took out the cabin air filter in my 04 Runner, blew it out and put it back in because my car interior is covered in black road dirt.
This morning I woke up to a Christmas tree on my dashboard. The Check engine light is on, the VSC light it on, the speedometer doesn't work, the gas gauge doesn't work properly and the ABS light is on.
The engine is running fine, I can stop as necessary and the 4WD is working properly. However, it is terribly unnerving to see that my vehicle is apparently going to explode or stop working altogether.
Did I jar any wires loose when I was removing the filter? There are tons of wires and connections under there so its totally possible.
Any help would be greatly appreciated.
make sure all ur fuses r good, if so, try resetting everything by disconnecting the - battery term for 5 min.
