Daystar 1.5" REAR lift
Mike Beyers
I know these kits have been covered extensively here, so I apologize in advance but.......I installed the 2" "leveling" kit in the front, and after an alignment, and about 1000 miles of driving, I am still "nose high". I found a 1.5" rear leveling kit on Amazon that says it will fit, but the box says it is for an FJ Cruiser. Will this fit? I am also installing Bilstein 5100s and new swaybar links. Figures I had to cut the links out when I did the front, so why not replace the rears as well.
This is from a thread I posted a while ago:
"I know it has been discussed recently but can't find the thread so my question. I have FJ rear spacer which installs spacer, bump stop, springs vs. 4runner which is bump stop, spacer, springs. The FJ setup seems to retain the stock 4runner clearance while while the 4runner setup would allow more travel. I loaded the truck to go camping and it was riding on the bump stop, but drove just fine. Question' swap spacers, cut 1.5" off bump stop, or leave as is. The fisrt two options obviously allow me 1.5" wheel travel gain while my current setup only gains me 1.5" of height. Thoughts?"
I ended up cutting the bump stops and have had no problems.
H.Sikina
