Daystar 1.5 spacer not fitting!!!! Help
I've got the rear of my 4runner jacked and have the spring and shock out and it looks like the spacer is not fitting in the rubber bump stop???? Help!!! Is this normal? Did I order the wrong part?
Thanks, want to install ASAP and I'm half way thought the process, may just put the new fj coils in until I can figure out the spacer issue.
http://img811.imageshack.us/img811/8476/spacerr.jpg
Install the spacer above the bumpstop. The 4runner spacer the bump stop fits inside, but the fj spacer it fits below (based on daystars instructions. This is the only difference between the 4runner and fjspacer that I'm aware of.
ARK, you are my hero, was rereading 4runner instructions and it was close but didn't fit with rubber bumpstop above the spacer then revaersed and put the spacer on top of the bump stop and it works!!! but the Spacer just is not 100% flush in old rubber seat on the frame. I'll give it a try and let you know.
THANKS!!!
lindwlson982
